Native integer code for Java
eudoxie
Post by eudoxie »
I've cleaned up some of the code I've posted earlier in this forum, and turned it into a small library for ternary mathematics and logic using host-native integers (that is, instead of storing digits in a vector, we store the number as a native integer, and use deep magic to simulate the effects of ternary operations, such as data type overflow.)
(It's also not truly base agnostic. There are a few lingering 3s around the Word code. But change them to 'base' and it should be alright)
For example
        Word w = new Word(3,6);
        TriLogic tri = new TriLogic(6);
        int a = 364;
        int b = 10;
        System.out.println("a = " + w.toString(a));
        System.out.println("b = " + w.toString(b));
        System.out.println("a + b = " + w.toString(w.wrap(a+b)) + " = " + w.wrap(a+b));
        System.out.println("a - b = " + w.toString(w.wrap(a+b)) + " = " + w.wrap(a-b));
        System.out.println("a * b = " + w.toString(w.wrap(a*b)) + " = " + w.wrap(a*b));
        System.out.println("digit-wise a xor b = " + w.toString(tri.commutative(tri.XOR, a, b)));
        System.out.println("digit-wise a or b = " + w.toString(tri.commutative(tri.OR, a, b)));
        System.out.println("digit-wise a and b = " + w.toString(tri.commutative(tri.AND, a, b)));
Produces
a = [1,1,1,1,1,1]
b = [1,0,1,0,0,0]
a + b = [-1,-1,0,-1,-1,-1] = -355
a - b = [-1,-1,0,-1,-1,-1] = 354
a * b = [1,1,-1,0,0,0] = -5
digit-wise a xor b = [1,0,1,0,0,0]
digit-wise a or b = [1,1,1,1,1,1]
digit-wise a and b = [1,0,1,0,0,0]
Code:
/* (C) 2011 Viktor Lofgren
 * Free for non-commercial use.
package tunguska.host_native;
 * Toolkit for native-integer balanced base arithmetic
 * <p>Use wrap() to simulate integer overflow, enabling native arithmetic.<br/>
 * <b>Example:</b> If you wish to simulate the calculation of a  b + c + d , call
 * wrap(wrap(ab) + c + d)</p>
 * <p><b>Caveat:</b> The digit-shifting operators are named according to
 * little-endian digit terminology (that is, shift right is similar to
 * a sort of division), but toInteger(int[] arry) and toArray(int v) use
 * big endian bit ordering.</p>
 * @author Viktor Lofgren
public class Word {
    public final int width;
    public final int base;
    final int[] powers;
    final int[] powers_2;
    int carry;
    public Word(int base, int width) {
        carry = 0;
        this.base = base;
        this.width = width;
        if((base-1) / 2 != base/2) {
            throw new ArithmeticException("Base must be odd");
        powers = new int[width+1];
        powers_2 = new int[width+1];
        powers[0] = 1;
        for(int i = 1; i <= width; i++) {
            powers[i] = powers[i-1]*base;
            powers_2[i] = powers[i] / 2;
     * Simulate integer overflow
    public int wrap(int i) {
        carry = i - _wrap(i);
        i = i - carry;
        carry /= powers[width];
        return i;
     * Simulate integer overflow at digit 'digit' (0 <= digit <= width)
    public int wrap(int i, int digit) {
        carry = i - _wrap(i, digit);
        i = i - carry;
        carry /= powers[digit];
        return i;
     *  Simulate integer overflow without setting carry
     *  @see wrap(int i)
    public int _wrap(int i) {
        if(i > 0)
            return (i + powers_2[width]) % powers[width] - powers_2[width];
        else
            return -(-i + powers_2[width]) % powers[width] + powers_2[width];
     *  @see wrap(int i, int digit)
    public int _wrap(int i, int digit) {
        assert(digit > 0 && digit <= width);
        if(i > 0)
            return (i + powers_2[digit]) % powers[digit] - powers_2[digit];
        else
            return -(-i + powers_2[digit]) % powers[digit] + powers_2[digit];
    /** Get carry of latest operation
    public int carry() {
        return carry;
    /** Digit-wise left shift */
    public int shift_left(int i, int digits) {
        carry = i - _wrap(i, width-digits);
        i = powers[digits] * (i - carry);
        carry /= powers[width-digits];
        return i;
    /** Single digit shift left */
    public int shift_left(int i) {
        carry = i - _wrap(i, width-1);
        i = base * (i - carry);
        carry /= powers[width-1];
        return i;
    /** Digit-wise shift right */
    public int shift_right(int i, int digits) {
        carry = _wrap(i, digits);
        return (i - carry) / powers[digits];
    /** Single digit shift right */
    public int shift_right(int i) {
        carry = _wrap(i, 1);
        return (i - carry) / 3;
    /** Digit-wise left shift, ignore carry */
    public int _shift_left(int i, int digits) {
        return powers[digits] * _wrap(i, width-digits);
    /** Single digit shift left, ignore carry */
    public int _shift_left(int i) {
        return base * _wrap(i, width-1);
    public int _shift_right(int i, int digits) {
        return (i - _wrap(i, digits)) / powers[digits];
    public int _shift_right(int i) {
        return (i - _wrap(i, 1)) / 3;
    /** Convert native integer to array of balanced base digits
     * with big endian digit order.
    public int[] toArray(int v) {
        int[] arry = new int[width];
        for(int i = 0; i < width && v != 0; i++) {
            if(v >= 0) {
                arry[i] = v - 3 * ( ( v + 1) / 3 );
                v = ( v + 1 ) / base;
            } else {
                arry[i] = v - 3 * ( ( v - 1 ) / 3);
                v = ( v - 1) / base;
        return arry;
    /** Convert array of balanced base digits to native integer.
     * Big endian digit order.
    public int fromArray(int[] digits) {
        int rv = 0;
        for(int i = digits.length-1; i >= 0; i--) {
            rv = base * rv + digits[i];
        return _wrap(rv);
    public String toString(int v) {
        StringBuilder rv = new StringBuilder();
        rv.append('[');
        for(int i : toArray(v)) {
            rv.append(i);
            rv.append(',');
        rv.setCharAt(rv.length()-1, ']');
        return rv.toString();
    /* Deep voodoo */
    public int getDigit(int value, int digit) {
        assert(digit >= 0 && digit < width);
        if(value >= 0) {
            return ( value + powers_2[digit] ) / powers[digit]
                    - base * (( value + powers_2[digit+1]) / powers[digit+1]);
        } else {
            return ( value - powers_2[digit] ) / powers[digit]
                    + base * (( -value + powers_2[digit+1]) / powers[digit+1]);
    public int setDigit(int i, int digit, int value) {
        return i + powers[digit] * ( value - getDigit(i, digit));
 * Balanced base 3 logic.
 * <p>The reason this isn't base-agnostic is because the number of possible
 *  operators in higher balanced bases is given by e<sup>2 b  ln(b)</sup>.
 * This function grows at a quite ridiculous rate.
 * </p>
 * <p>Base 3 has 729 commutative operators<br />
 * Base 5 has 9 765 625 commutative operators <br />
 * Base 7 has 678 223 072 849 commutative operators <br />
 * Base 9 has 150 094 635 296 999 121 commutative operators</p>
 * So realistically, only base 3 is possible.
public class TriLogic {
    final int[][] commutative;
    public final int XOR =  construct(1, 0, 1,
                                      0, -1, 0);
    public final int OR =   construct(-1, 0, 1,
                                      0, 1, 1);
    public final int AND =  construct(-1, 0, 1,
                                     -1, -1, 0);
    public final int SHIFT = construct(1, 0, -1,
                                        -1, 0, 1);
    public final int SHIFT_NO_ROTATE = construct(-1, 0, 1,
                                        -1, 0, 1);
    final Word word;
    static int construct(int ff, int uu, int tt, int fu, int ft, int ut) {
        return ff + 3 * uu + 9 * tt + 27 * fu + 81 * ft + 243 * ut;
    public TriLogic(int width) {
        commutative = new int[729][];
        word = new Word(3, width);
        Word tryte = new Word(3,6);
        for(int i = 0; i < 729; i++) {
            commutative[i] = tryte.toArray(i-364);
    /** Commutative operator given by oper. Native-integer coded
     * ternary word of width 6 (a tryte) so that
     * <table border style="margin: 1em">
     *  <tr>
     *   <th>a[i]</th>
     *   <th>b[i]</th>
     *   <th>oper(a[i], b[i])</th>
     *  </tr>
     *  <tr>
     *   <td> -1 </td> <td> -1 </td> <td> oper[0] </td> </tr>
     *   <td> 0 </td> <td> 0 </td> <td> oper[1] </td> </tr>
     *   <td> 1 </td> <td> 1 </td> <td> oper[2] </td> </tr>
     *   <td> -1 </td> <td> 0 </td> <td> oper[3] </td> </tr>
     *   <td> -1 </td> <td> 1 </td> <td> oper[4] </td> </tr>
     *   <td> 0 </td> <td> 1 </td> <td> oper[5] </td> </tr>
     *  </tr>
     * </table>
     public int commutative(int oper, int a, int b) {
        if(oper == XOR) return xor(a,b);
        int[] operator = commutative[364 + oper];
        int d = 0;
        for(int i = 0; i < word.width; i++) {
            a = word.shift_right(a);
            int ai = word.carry();
            b = word.shift_right(b);
            int bi = word.carry();
            int di = 0;
            if(ai == bi)
                di = operator[1+ai];
            else {
                di = operator[4+bi + ai];
            d += word.powers[i] * di;
        return d;
    public int invert(int a) {
        int b = 0;
            b -= word.powers[i] * word.carry();
        return b;
    public int inc(int a) {
        int b = 0;
            int ai = word.carry() + 1;
            if(ai > 1) ai = -1;
            b -= word.powers[i] * ai;
        return b;
    public int dec(int a) {
        int b = 0;
            int ai = word.carry() - 1;
            if(ai < -1) ai = 1;
        return b;
    int xor(int a, int b) {
        int d = 0;
            d += word.powers[i] * (ai * bi);
        return d;
moving up
