A 6502 emulator on Go
askfind
Post by askfind »
Ссылка на проект: https://github.com/beevik/go6502
go6502 is a collection of go packages that emulate a 6502 or 65C02 CPU. It includes a CPU emulator, a cross-assembler, a disassembler, a debugger, and a host that wraps them all together.
The interactive go6502 console application in the root directory provides access to all of these features.
go6502 - это набор пакетов для языка программирования GO.
Что умеет? Эмуляция процессоров 6502 или 65C02, кросс-ассемблер, дизассемблер, отладчик и хост, который объединяет их все вместе.
Интерактивное консольное приложение go6502 в корневом каталоге обеспечивает доступ ко всем этим функциям.
> $ go6502
* help
go6502 commands:
    annotate         Annotate an address
    assemble         Assemble commands
    breakpoint       Breakpoint commands
    databreakpoint   Data breakpoint commands
    disassemble      Disassemble code
    evaluate         Evaluate an expression
    execute          Execute a go6502 script file
    exports          List exported addresses
    list             List source code lines
    load             Load a binary file
    memory           Memory commands
    quit             Quit the program
    register         View or change register values
    run              Run the CPU
    set              Set a configuration variable
    step             Step the debugger
* load sample.bin
Loaded source map from 'sample.map'.
Loaded 'sample.bin' to $1000..$10FF.
* disasm $1000
Command not found.
* disassemble $1000
1000-   A9 EE       LDA   #$EE
1002-   A9 FE       LDA   #$FE
1004-   A9 80       LDA   #$80
1006-   A9 7F       LDA   #$7F
1008-   A9 5A       LDA   #$5A
100A-   20 21 10    JSR   $1021
100D-   20 24 10    JSR   $1024
1010-   20 3E 10    JSR   $103E
1013-   20 4E 10    JSR   $104E
1016-   F0 08       BEQ   $1020
* quit
