GeckOS Operating System for the 6502 processor
askfind
c) 1989-2023 A. Fachat (afachat@gmx.de)
This repository maintains the GeckOS/A65 source.
https://github.com/fachat/GeckOS-V2/tree/master
GeckOS comes of course with no warranty in any form. See the file COPYING for the GNU public license.
The doc directory contains all necessary documentation (in asciidoc mostly). I propose reading doc/index.adoc first.
The RELEASE NOTES describe what’s new in the current release.
In the repository, kernel, lib6502, devices and include are general source directories.
The apps folder holds pure lib6502 applications, like a shell, mkdir, etc. They should also assemble for other lib6502 operating systems.
sysapps holds OS/A65 specific programs, like the slipd, or the filesystem servers.
Ports
The previous directories are very independent from the actual system architecture. The arch directory holds the architecture specific parts. It contains a directory for each supported architecture. "proto" holds a prototype architecture that can be used for porting.
Here you can find the current set of disk images for the currently active ports:
PET 32k osa.d64
CBM 8x96 osa.d64
CS/A65 osa.d64
C64 osa.d64
Have fun!
22sept2023 André Fachat
