Re: Тримулятор
тримулятор
По дороге из Маями в Нью-Йорк начал писать "тримулятор", который бы эмулировал троичную логику на Java, причем на уровне ключей и компараторов, а не троичных блоков, т.е. предельно близко к железной реализации - из-за этого пришлось ввести в алфавит четвертое состояние U (unplugged). Вот описание модулей на гипотетическом языке описания схем (наверное он будет частью jEmul):
 Signals (alphabet T):
 N - negative (-1)
 O - ground (0)
 P - positive (+1)
 U - unplugged
 Special marks:
 ! - last value (used in simulation of memory)
 ? - bad value (used as exception mark in simulation)
 Unary blocks:
 MEM - memory cell
 BUF - buffer
 INV - inverter
 BLN - block negative (foreward diode)
 BLP - block positive (backward diode)
 PRP - pull-up resistor to +1
 PRO - pull-down resistor to 0
 PRN - pull-down resistor to -1
 CAO - comparator above O (>0)
 CAN - comparator above N (>-1)
 CBO - comparator below O (<0)
 CBP - comparator below P (<+1)
 Binary blocks:
 NOD - node (2->1)
 SOP - switch O-off P-on
 SPO - switch P-off O-on
 SNP - switch N-off P-on
 SPN - switch P-off N-on
 Schemes:
 BUF2 - buffer with 3 outputs
 INV2 - inverter with 3 outputs
alf T:N,O,P,U "Ternary alphabet for hardware implementation"
def MEM T:T "Memory"
 N:N
 O:O
 P:P
 U:!
end
def BUF T:T "Buffer"
 N:N
 O:O
 P:P
 U:?
end
def INV T:T "Inverter"
 N:P
 O:O
 P:N
 U:?
end
def BLP T:T "Block positive"
 N:N
 O:U
 P:U
 U:U
end
def BLN T:T "Block negative"
 N:U
 O:U
 P:P
 U:U
end
def PRP T:T "Pull-up resistor to +1"
 N:N
 O:O
 P:P
 U:P
end
def PRO T:T "Pull-down resistor to 0"
 N:N
 O:O
 P:P
 U:O
end
def PRN T:T "Pull-down resistor to -1"
 N:N
 O:O
 P:P
 U:N
end
def CAO T:T "Comparator above O"
 N:N
 O:N
 P:P
 U:?
end
def CAN T:T "Comparator above N"
 N:N
 O:P
 P:P
 U:?
end
def CBO T:T "Comparator below O"
 N:P
 O:N
 P:N
 U:?
end
def CBP T:T "Comparator below P"
 N:P
 O:P
 P:N
 U:?
end
def NOD TT:T "Node 2->1"
 NN:?
 NO:?
 NP:?
 NU:N
 ON:?
 OO:?
 OP:?
 OU:O
 PN:?
 PO:?
 PP:?
 PU:P
 UN:N
 UO:O
 UP:P
 UU:U
end
def SOP TT:T "Switch O-off P-on"
 NN:?
 NO:U
 NP:N
 NU:?
 ON:?
 OO:U
 OP:O
 OU:?
 PN:?
 PO:U
 PP:P
 PU:?
 UN:?
 UO:U
 UP:U
 UU:?
end
def SPO TT:T "Switch P-off O-on"
 NN:?
 NO:N
 NP:U
 NU:?
 ON:?
 OO:O
 OP:U
 OU:?
 PN:?
 PO:P
 PP:U
 PU:?
 UN:?
 UO:U
 UP:U
 UU:?
end
def SNP TT:T "Switch N-off P-on"
 NN:U
 NO:?
 NP:N
 NU:?
 ON:U
 OO:?
 OP:O
 OU:?
 PN:U
 PO:?
 PP:P
 PU:?
 UN:U
 UO:?
 UP:U
 UU:?
end
def SPN TT:T "Switch P-off N-on"
 NN:N
 NO:?
 NP:U
 NU:?
 ON:O
 OO:?
 OP:U
 OU:?
 PN:P
 PO:?
 PP:U
 PU:?
 UN:U
 UO:?
 UP:U
 UU:?
end
Re: тримулятор
Shaos wrote:По дороге из Маями в Нью-Йорк начал писать "тримулятор", который бы эмулировал троичную логику на Java, причем на уровне ключей и компараторов, а не троичных блоков, т.е. предельно близко к железной реализации - из-за этого пришлось ввести в алфавит четвертое состояние U (unplugged). Вот описание модулей на гипотетическом языке описания схем (наверное он будет частью jEmul)
Можно еще добавить три модуля, выдающие уровни сигналов, соответственно, N O P. В реальной схеме это будет просто подключение к -5В, земле, +5В. Если кому интересно, логика на диодах, подцепляемых к CMOS, называется "Mickey-Mouse Logic" или MML ;)
https://web.archive.org/web/20050510232444/http://musicfromouterspace.com/analogsynth/mmlogic.html
Вот модифицированные правила (с новым jEmul-синтаксисом):
 N - negative (-1)
 O - ground (0)
 P - positive (+1)
 U - unplugged
 Special marks:
 Unary blocks:
 MEM - memory cell
 BUF - buffer
 INV - inverter
 Binary blocks:
 NOD - node (2->1)
 Schemes:
alf T={N,O,P,U} "Ternary alphabet for hardware implementation"
def MEM (T:T) "Memory"
 N:N
 O:O
 P:P
 U:!
end
def BUF (T:T) "Buffer"
 N:N
 O:O
 P:P
end
def INV (T:T) "Inverter"
 N:P
 O:O
 P:N
end
def BLP (T:T) "Block positive"
 N:N
 O:U
 P:U
 U:U
end
def BLN (T:T) "Block negative"
 N:U
 O:U
 P:P
 U:U
end
def PRP (T:T) "Pull-up resistor to +1"
 N:N
 O:O
 P:P
 U:P
end
def PRO (T:T) "Pull-down resistor to 0"
 N:N
 O:O
 P:P
 U:O
end
def PRN (T:T) "Pull-down resistor to -1"
 N:N
 O:O
 P:P
 U:N
end
def CAO (T:T) "Comparator above O"
 N:N
 O:N
 P:P
end
def CAN (T:T) "Comparator above N"
 N:N
 O:P
 P:P
end
def CBO (T:T) "Comparator below O"
 N:P
 O:N
 P:N
end
def CBP (T:T) "Comparator below P"
 N:P
 O:P
 P:N
end
def NOD (T,T:T) "Node 2->1"
 N,U:N
 O,U:O
 P,U:P
 U,N:N
 U,O:O
 U,P:P
 U,U:U
end
def SOP (T,T:T) "Switch O-off P-on"
 N,O:U
 N,P:N
 O,O:U
 O,P:O
 P,O:U
 P,P:P
 U,O:U
 U,P:U
end
def SPO (T,T:T) "Switch P-off O-on"
 N,O:N
 N,P:U
 O,O:O
 O,P:U
 P,O:P
 P,P:U
 U,O:U
 U,P:U
end
def SNP (T,T:T) "Switch N-off P-on"
 N,N:U
 N,P:N
 O,N:U
 O,P:O
 P,N:U
 P,P:P
 U,N:U
 U,P:U
end
def SPN (T,T:T) "Switch P-off N-on"
 N,N:N
 N,P:U
 O,N:O
 O,P:U
 P,N:P
 P,P:U
 U,N:U
 U,P:U
end
sch TEST "Test"
 >T i1 3 3
 >T i2 3 5
 <T o1 10 3
 <T o2 10 5
 +SPN obj 5 5
 @obj.0 i1
 @obj.1 i2
 @o1 obj.0
 @o2 =P
end
Исчез символ '?' - теперь любое неописанное состояние будет неопределенным и специально его задавать ненужно. Внизу виден пример описания схемы TEST, собранной из троичных модулей.
Я снова слегка видоизменил jem-синтаксис:
 N - negative (-1)
 O - ground (0)
 P - positive (+1)
 U - unplugged
 Special marks:
 Unary blocks:
 MEM - memory cell
 BUF - buffer
 INV - inverter
 Binary blocks:
 NOD - node (2->1)
 Schemes:
alf T=N,O,P,U "Ternary alphabet for hardware implementation"
 N:N
 O:O
 P:P
 U:!
end
 N:N
 O:O
 P:P
end
 N:P
 O:O
 P:N
end
 N:N
 O:U
 P:U
 U:U
end
 N:U
 O:U
 P:P
 U:U
end
 N:N
 O:O
 P:P
 U:P
end
 N:N
 O:O
 P:P
 U:O
end
 N:N
 O:O
 P:P
 U:N
end
 N:N
 O:N
 P:P
end
 N:N
 O:P
 P:P
end
 N:P
 O:N
 P:N
end
 N:P
 O:P
 P:N
end
 NU:N
 OU:O
 PU:P
 UN:N
 UO:O
 UP:P
 UU:U
end
 NO:U
 NP:N
 OO:U
 OP:O
 PO:U
 PP:P
 UO:U
 UP:U
end
 NO:N
 NP:U
 OO:O
 OP:U
 PO:P
 PP:U
 UO:U
 UP:U
end
 NN:U
 NP:N
 ON:U
 OP:O
 PN:U
 PP:P
 UN:U
 UP:U
end
 NN:N
 NP:U
 ON:O
 OP:U
 PN:P
 PP:U
 UN:U
 UP:U
end
sch TEST "Test"
 >T i1 3 3
 >T i2 3 5
 <T o1 10 3
 <T o2 10 5
 +SPN obj 5 5
 @obj.0 i1
 @obj.1 i2
 @o1 obj.0
 @o2 =P
end
Вернулся к тримулятору - почти дописал Jem-парсер. Описатель Jem-схем слегка упростился:
sch test "Test"
 >T i1 3,3
 >T i2 3,5
 +SPN obj 5,5 i1 i2
 <T o1 10,3 obj.0
 <T o2 10,5 =P
end
символ > описывает вход
символ < описывает выход
символ + вставляет блок
будет еще символ = означающий вход-выход (I/O)
CHRV
Post by CHRV »
По заказу Мак-Бастера пишу щаз на Джаве в свободное время абстракцию эмулятора троичного проца с памятью похожего архитектурой PDP11. С возможностью пошагового и брекпоинтового дебаганья, но без реализации логики работы процессора и парсинга команд, для примера сделаю несколько команд, а потом МБР пусть сам делает. Моя версия предоставлять будет чисто среду для откатки набора команд и вообще для изучения троичной логики.
Буду извещать по ходу работ. Пока сделан базовый класс Tryte со всевозможной логикой работы с Tryte-ами.
Скорей всего буду для визуализации использовать AWT и Swing, так что Шурик потом в апплет если захочет легко передерет.
Re: тримулятор
Может лучше назвать это состояние Z? Это вроде общепринятое обозначение для отключенного выхода.
Alik
Dead
Re: тримулятор
Post by Alik »
По поводу "Mickey-Mouse Logic" - это американец похож на школьника, который доказал теорему Пифагора. Одно мне не понятно - зачем делать такой расширитель по входу, если есть стандартные вентили И-НЕ.
Конечно же Z, в железе это все ключи разомкнуты.
Эмулятор штука важная, поэтому у меня вопрос: как определяется задержка в прохождении сигнала через вентиль?
По троичной арифметике обнаружил недавно очень хорошее описание, автор Александр Никитич. Участвует ли он в этом форуме?
Re: тримулятор
Alik wrote:По поводу "Mickey-Mouse Logic" - это американец похож на школьника, который доказал теорему Пифагора. Одно мне не понятно - зачем делать такой расширитель по входу, если есть стандартные вентили И-НЕ.
Как ни странно - этот термин есть в американских книжках по CMOS, изданных еще в 70-х ;)
Alik wrote: Эмулятор штука важная, поэтому у меня вопрос: как определяется задержка в прохождении сигнала через вентиль?
Можно сделать быстрый вариант - прохождение сигнала в прямом направлении мгновенно (в пределах одного такта), а в обратных связях с задержкой на один такт. А можно сделать медленный - когда каждый элемент будет привносить задержку в один такт эмуляции.
Alik wrote: По троичной арифметике обнаружил недавно очень хорошее описание, автор Александр Никитич. Участвует ли он в этом форуме?
Да - он написал несколько сообщений в ternary.info и давал там ссылку на свою заметку о троичной системе счисления
Alik
Dead
Re: тримулятор
Post by Alik »
Shaos wrote: Можно сделать быстрый вариант - прохождение сигнала в прямом направлении мгновенно (в пределах одного такта), а в обратных связях с задержкой на один такт. А можно сделать медленный - когда каждый элемент будет привносить задержку в один такт эмуляции.
Nado delat' kak v jizni: zaderzhka opredelyetsya tol'ko ventilyami (CMOS: 5-20ns), no v simulyatore luchshe sdelat' option: "Select gates delay time"
Программа разложения целого числа в троичное представление:
http://www.oleg.314159.ru/index.htm
Взаимообратные числа и их применение
http://www.trinitas.ru/rus/doc/0232/009a/02320004.htm
Shaos, vozmojno ty skajesh' - poka nado sdelat' "clear ternary simulation" bez etih navorotov, ladno...
But! Have place the problem of interface between blocks, predlagayu sdelat' ego kak TRIMOSBUS. Avtor originala Ivan Sutherland ego stat'yu ya poprosil otskanirovat', budet gotovo tol'ko v marte, posle my exams.
Ochen' horosho napisano ob etom u Varshavskogo, (lejit u menya na saite) in english
Re: тримулятор
Post by Mac Buster »
Alik wrote:Программа разложения целого числа в троичное представление:
Эта программа преобразует число в избыточную Стаховскую систему.
Extreme Entertainment
Alexandr
Re: тримулятор
Post by Alexandr »
Alik wrote:По троичной арифметике обнаружил недавно очень хорошее описание, автор Александр Никитич.
Спасибо.
Alik wrote:Участвует ли он в этом форуме?
Участвую.
Re: Тримулятор
Самое последние описание стандартного набора блоков всегда будет доступно тут:
http://nedopc.org/ternary/rules.txt
Re: Тримулятор
В моей голове немного проясняется архитектура Тримулятора (а вместе с ней и детали более глобального jEmul-ятора). Итак, сама по себе программа будет являться Java-апплетом, который будет работать с файлами, лежащими на сервере в каталоге с class-файлами:
- файлы с расширением .jem - описание блоков и схем;
- файлы с расширением .jes - описание скриптов эмуляции;
- файлы с расширением .jep - описание проектов.
Формат файла проекта (элементы списков разделяются запятыми) :
scheme=имя_схемы_проекта
authors=список_авторов
sources=список_файлов_блоков
scripts=список_файлов_скриптов
watches=список_переменных_для_просмотра
В то же время я планирую создать некие PHP-средства создания и редактирования новых файлов для Тримулятора - тогда зарегистрированные посетители нашего портала смогут сами создавать и отлаживать новые схемы в троичной логике!
Re: Тримулятор
Что-то забросил я тему - пора завершать и вывешивать...
