Solid C: devel-1.txt
 PRINCIPLE OF SEPARATED COMPILING
When you develop large program usually source code is separated
to some files.  These files compile separately and linked into
one program. Here we describe method of separated compiling and
note general points that must be important during sourcecode
writing.
 1. Notes to sourcecode
There are two serious problems of separated compiling of large
programs:
 - links to functions from other files;
 - ability to get common data.
Below we try to solve that problems with examples. See this
program:
#include <stdio.h>
int  a[10];
char b[4];
char main()
        char sub1(),sub2();
        sub1();
        sub2();
        printf("%d,%d,%d\n",a[0],a[3],a[9]);
        printf("%c,%c,%c\n",b[0],b[1],b[2]);
char sub1()
        a[0]=1;
        a[3]=2;
        a[9]=3;
char sub2()
        b[0]='a';
        b[1]='b';
        b[2]='c';
Text of the program is divided on three files namely PROG1,
PROG2 and PROG3 that consist of main function and functions
1 and 2:
PROG1.C:
        #include <stdio.h>
        int a[10];
        char b[4];
        char main()
PROG2.C:
        extern int a[10];
        char sub1()
PROG3.C:
        extern char b[4];
        char sub2()
Function "main" calls functions "sub1" and "sub2" and we need
use definition of that functions. Functions "sub1" and "sub2"
call nothing and do not need in any function definitions.  Using
arrais "a" and "b" is a problem too. Identifier "a" used in "main"
and "sub1". Identifier "b" used in "main" and "sub2". For all
of that files must be linked.
To link identifiers word "extern" is used. In first file
PROG1.C this word is not needed, but in other two files it is. It
reflects that arrays "a" and "b" defined in file PROG1.C, but in
other files these arrays are absent. If a number of files will use
definitions without word "extern" error of name duplicating
appears. In other hand we can't use "extern" in all definitions
because it may be undefined object. Therefore we must be use the
only definition without "extern". All other definitions of the same
identifier must be "extern".
 2. Compile and link
Described above sourcecode must be compiled and linked by the
sequence of actions:
        cc1 prog1
        cc1 prog2
        cc1 prog3
        cc2 prog1
        cc2 prog2
        cc2 prog3
        as prog1
        as prog2
        as prog3
        ld prog=prog1,prog2,prog3,clib/l/gXMAIN
If all parts (all files) are compiled already and we need
recompile the only file (for example PROG2.C) another sequence must
be used:
        cc1 prog2
        cc2 prog2
        as prog2
