Кросс-ассемблер ZMAC v1.33
http://nedopc.org/nedopc/sprinter/download/zmac133.zip (131Kb)
Новая версия ZMAC v1.33 с добавлениями от Vasil Ivanov
2005-03-30  Vasil Ivanov from http://forum.nedopc.org
	* Version 1.33 -- changes were done directly in generated zmac.c
	* All messages stderr now go to stdout to be able to redirect everything to 1 file
	* Fixed issue in new function doincbin() that caused "phase error".
2005-02-25  Vasil Ivanov from http://forum.nedopc.org
	* Version 1.32 -- changes were done directly in generated zmac.c
	* Put all labels starting with @ to file .tbl
	* Added directive INCBIN to include binary file
	* Note: Quotation is not needed for include and incbin
	* Note: This assembler doesn't know undocumented instructions
2005-02-?? Vasil Ivanov from http://forum.nedopc.org
	* Version 1.31 -- changes were done directly in generated zmac.c
	* Some changes from above (sources were lost)
2000-07-02  Mark RISON  <mrison@hotmail.com>
	* Version 1.3.
	* Improve man page (including portability fixes by Tim).
	* From Matthew, Tim and Russell: compiler warning avoidance.
2000-06-25  Mark RISON  <mrison@hotmail.com>
	* Version 1.3b4.
	* Allow benign EQU redefinition.
	* Cut down on warnings in pass 1.
	* Find and (hopefully!) fix nasty bug in error recovery in arglists.
	* Allow JP HL/IX/IY syntax.  A warning is issued.
	* Revamp man page.
	* From Tim Mann: resolve r/r conflict for parentheses in expressions.
2000-06-18  Mark RISON  <mrison@hotmail.com>
	* Version 1.3b3.
	* BeOS now supported (just treat as a Un*x variant!).
	* Upgrade to bison 1.28 so alloca () no longer a problem.
	* Document the operator zoo.
	* Allow normal parentheses in expressions.
	  (FIXME: is there a way to tell bison the r/r conflict is OK?)
	* From Tim Mann: sort out operator precedence; make it C-like.
2000-05-25  Mark RISON  <mrison@hotmail.com>
	* Version 1.3b2.
	* Fix error handling fix (with Tim's help!).
	* From Tim Mann: add relationals and synonyms for NOT, MOD, SHL, SHR.
2000-03-18  Mark RISON  <mrison@hotmail.com>
	* Version 1.3b1.
	* Fix error handling.
	* Allow a leading colon or no special character at all
	to introduce a label.
	* Allow $ and # to introduce hex constants.
	* Allow COND and ENDC as synoyms for IF and ENDIF.
	* More ANSI C pedantry.
	* From Tim Mann: remove the nasty and buggy hack to allow AND,
	OR and XOR to be used as binary operators and do it properly.
	* From Tim Mann: fix bug which prevented & from being used as
	a binary operator when it was allowed to introduce a hex constant.
	* From Matthew Phillips: try filename as given before trying
	to add a '.z' extension.
2000-02-27  Mark RISON  <mrison@hotmail.com>
	* Version 1.2.
	* Stop trying to add an extension to INCLUDEd files
	(this stupid idea was a misfeature introduced in 1.1.1.1).
	Instead, define canonical form, which is automatically
	decanonicalised according to the local OS requirements
	(see the man page for more details).
	* Add support for RISC OS.
	* Increase the maximum number of IFs to 1024.
	* Issue warning when SLL is used.
	* Further ANSI C-ify.
	  (FIXME: anyone know how to convince bison not to use alloca ()?)
	* Tweak command-line error reporting.
	* Remove legacy non-ANSI C garbage.
	* From Matthew Phillips: add support for outputting AMSDOS header.
	* From Matthew Phillips: add support for RISC OS DDE throwback.
2000-02-11  Russell Marks  <russell.marks@dtn.ntl.com>
	* zmac.1: updated man page.
	* zmac.y: changed `-O' warning output to look more like gcc
	(`foo.z:N: warning: wibble' rather than `foo.z:N: wibble
	warning').
	* zmac.y: changed to use my old getoptn() getopt clone instead of
	`real' getopt(), as I know Mark likes his portability :-) (and it
	probably wouldn't work on DOS otherwise, which even I would like
	it to...).
	* zmac.y: merged in changes (relative to 1.1) from my current
	zmac. These were:
	* zmac.y: minor changes to avoid egcs/gcc `ambiguous else'
	warnings.
	* zmac.y: changes from Chris Smith [slightly changed to fit zmac
	1.1.1.x]. `-o' now specifies output file; `-x' specifies listing
	file (`-x -' does the same as the old `-o' option); the
	undocumented `sll' opcode is now allowed; "Cannot open foo file"
	errors now give the filename; a `.z' extension is only added to
	source filename if it has no extension; args are now parsed with
	getopt().
	* Makefile: fix missing dependencies for zmac.
1999-10-03  Mark RISON  <mrison@hotmail.com>
	* Version 1.1.1.2.
	* Fix bug in nested ELSEs.
	* Pad .bin file when multiple ORGs are used.
	* `-O' option invokes optimisation suggester
	  for JP, RLC/RRC/RL/RR/SLA A and LD A, 0.
	* Reinstate 0x02, 0x0a, 0x12 and 0x1a as valid 8080 opcodes.
	* Add zmac.c to .zip file (for those who don't have yacc/bison).
	* Make makefile no longer depend on GNU make implicit rules.
1999-07-18  Mark RISON  <mrison@hotmail.com>
	* Version 1.1.1.1 (nee 1.1.1).
	* Extend symbol significance from 15 to 40 chars.
	  A warning is issued regarding truncated symbols.
	* Make continuous listing be the default.
	* Add ELSE to IF/ENDIF construct.
	* Allow INCLUDE filename to be delimited by " or '.
	* Allow labels to be defined using .name (as well as name:).
	* Allow ADD/SBC/ADD s syntax (implicit "A, ").
	* Issue warning for SUB/AND/XOR/OR/CP A, s syntax (explicit "A, ").
	* Issue warning for CMP and JMP opcodes, and V and NV condition codes.
	* Catch division by zero in expressions.
	* Allow hex constants to be specified using a leading '&'.
	  (FIXME: what's all this testing of nextchar () against '$' for?)
	* Add DB, DEFM and TEXT as synonyms for DEFB.
	* Add DS and RMEM as synonyms for DEFS.
	* Add DW as synonym for DEFW.
	* Add READ as synonym for INCLUDE.
	* Allow strings to be specified using " too.
	* Allow AND, OR and XOR to be used as binary operators.
	  (FIXME: a bit of a nasty hack; can it be done more cleanly?)
	* Make file handing consistent for source and INCLUDE:
	  for both, try to open with ".z" first, then with no extension.
1998-12-15  Russell Marks  <rus@lifeson>
	* Version 1.1.
	* Added support for --help and --version.
	* zmac.1: mentioned `title' pseudo-op.
	* Converted revision history from zmac.y into Emacs change log
	format (roughly).
	* Now outputs errors more like a C compiler (one per line,
	prefixed with filename and line-in-file), useful for `M-x compile'
	in Emacs. New `-S' option makes it show the error-causing line
	like it used to.
	* Made it output current file for error reports.
	* Added `void' to prototypes for funcs with no args.
	* Removed unnecessary `char *ctime()' and `fflush(stderr)'.
	* Made it support filenames longer than 14 chars!
1998-02-26  Russell Marks  <rus@lifeson>
	* Version 1.0 (for the sake of argument).
	* Made usage message say what the program is. :-)
1998-02-12  Russell Marks  <rus@lifeson>
	* Added verbose inline errors in listing and made the original
	terse one-letter ones available via new `-t' option.
	* Added `-c' option to produce continuous listing (no page breaks
	or page headers).
	* Corrected plurals in listing so you don't get things like "1
	symbols" any more.
	* Added `-z' option to output 8080-compatible code only - i.e., to
	flag Z80-specific ops as errors.
1998-02-11  Russell Marks  <rus@lifeson>
	* Fixed LIST-without-args segfault.
	* Allowed decimal constants to be up to 65535 (rather than up to
	32767 before; I checked and there was no reason for the previous
	exception for decimal even on systems with 16-bit ints).
	* Removed the `-d' debug option.
	* Removed the `-t' option. It did everything as normal *except*
	for not reporting errors. I can't imagine any valid reason for
	wanting that.
	* Made exit status 1 if there were errors in the assembly.
	* Fixed `equ' bug - it now detects forward refs to `equ's with
	forward refs and flags them as errors (because of course you'd
	need three passes to resolve them). The fix is pretty
	nasty-looking but it was really the only way I could see to do it.
	Some assemblers (e.g. Hisoft's GENS4) don't allow forward refs in
	`equ's at all, so count yourselves lucky! :-)
	* Changed symbol table listing so it fits in 80 columns.
	* Fixed `if' to not depend on internals of yacc parser (which
	appear to have changed, anyway).
	* Added support for normal `rst' format (0, 8, 10h, 18h...; still
	allows the previous 0, 1, 2, 3...).
	* Made default output binary (as .bin), added `-h' to get .hex.
	* ANSIfied the thing (painful!) and cleaned up a little.
1987-02-05  Colin Kelley
	* Added 'cmp' as a synonym for 'cp', 'jmp' as a synonym for 'jp',
	and added tolerance of accumulator specification for arithmetic
	and logical instructions. (For example, 'or a,12' is now accepted,
	same as 'or 12'.)
1987-01-18  Colin Kelley
	* Added MIO code to emulate 'mfile' using malloc()'d memory. This
	was needed to get the code to work when compiled under MSC 4.0 on
	a PC, and it's probably faster anyway.
1986-10-02  Colin Kelley
	* Added some more typecasts to keep lint a little happier. Removed
	several unused variables. Changed most vars declared as char to
	int, since many of them were being compared with -1! I still don't
	know what's going on with est[][] being malloc'd and free'd
	everywhere...it looks pretty fishy...
1986-09-20  Colin Kelley
	* Converted to run on a Pyramid. This meant changing yylval to be
	a %union, and then putting in the appropriate typecasts where ints
	are pointers are used interchangeably. The current version still
	probably won't run on machines where
	sizeof(int) != sizeof(char *).
	Also changed emit() to use varargs, and got rid of the old
	style = in front of yacc action code.
1984-08-27  John Providenza
	* Added PHASE/DEPHASE commands.
1984-05-22  John Providenza
	* Added include files ala ormac.
1984-05-11  John Providenza
	* Added code to print unused labels out with the symbol table.
	Also sped up the macro processor by using stdio.
1983-06-07  John Providenza
	* Fixed bug in the ADD IX,... instruction.
1983-02-15  John Providenza
	* Fixed 'getlocal' to return better local labels. It used to crash
	after 6 invocations.
1982-03-15  John Providenza
	* Changed maximum number of characters in a label to 15 from 7.
	Note that 'putsymtab' uses this value inside of a quoted string,
	so we use 15.
	* Added underscore as a character type in the lex table 'numpart'
	(0x5F).
1982-03-08  John Providenza
	* Converted to run on Vax, updated syntax to conform better to the
	Zilog standard.
1978-04-??  Bruce Norskog
	* Initial version.
Re: Кросс-ассемблер ZMAC
Добавил исходники zmac в репу nedoPC SDK:
https://gitlab.com/nedopc/sdk/-/tree/master/zmac?ref_type=heads
Re: Кросс-ассемблер ZMAC v1.33
Сборка чуть более новым gcc v12.2.0 показывает вот такие вот Warnings:
> gcc -O -Wall -o zmac zmac.c mio.c getoptn.c
mio.c: In function ‘mfputc’:
mio.c:57:75: warning: pointer used after ‘realloc’ [-Wuse-after-free]
   57 |                         mptr = (unsigned char *) (p + (unsigned int)(mptr - mhead));
mio.c:51:26: note: call to ‘realloc’ here
   51 |                 if ((p = realloc(mhead,msize+MALLOC_SIZE)) == (unsigned char *)-1) {
mio.c: In function ‘mfwrite’:
mio.c:114:83: warning: pointer used after ‘realloc’ [-Wuse-after-free]
  114 |                                 mptr = (unsigned char *) (p + (unsigned int)(mptr - mhead));
mio.c:108:34: note: call to ‘realloc’ here
  108 |                         if ((p = realloc(mhead,msize+MALLOC_SIZE)) == (unsigned char *)-1){
make[1]: Leaving directory '/home/shaos/src/nedoPC.org/zmac'
Надо будет как-нибудь исправить...
