The tape in from the Sprinter 2000 did not work. I use my pc with soundcard and a cable. With my ZX48K the same configuration works.
Is it generally possible to load games from tape in?
Micky
Tape in without function
-Micky
- Novelist
Re: Tape in without function
I believe you should switch Sprinter to normal speed (F11?) instead of "turbo" in order to use tape-in (disclimer: I never used tape-in on my Sprinter).-Micky wrote:The tape in from the Sprinter 2000 did not work. I use my pc with soundcard and a cable. With my ZX48K the same configuration works.
Micky
-Micky
- Novelist
