концепт 1-битного планшета на электронной бумаге
antsnark
Post by antsnark »
http://www.designboom.com/weblog/cat/16 ... paper.html
своими словами - однобитный планшет. Может нарисованные на нём картинки сохранять как PDF
цитата с сайта:
the 'noteslate' concept is a minimalist take on the tablet, designed as electronic paper with a minimalist aesthetic and simple interface, 'noteslate' is designed as an electronic alternative to paper.
the limited-function tablet is currently in the concept stage, although its designers claim a projected release date
of june 2011, with models planned to retail at .
the 1-bit colour models feature green, red, or blue on a black screen
with a 13-inch matte screen, 'noteslate' is the size of an A4 sheet of paper, and reads and write files as '.pdf'.
all models except one are 1-bit colour, offering the choice of black on a white screen,
or white, red, blue, or green on a black screen; the additional version features all four colours on black.
the user interface consists of three buttons: 'save current screen', 'delete current screen', and 'view previous screen'.
basic hardware input (USB, headphones, and SD card) are located at the top of the device,
along with a magnetic holder for the electronic pen with eraser.
streamlined for simplicity, the only additional features of 'noteslate' are optional wifi (without browsing capabilities)
and mp3 playback. its low-tech nature allows a single battery charge to provide 180 hours of use.
по концепции вещица вполне в духе недопэцэ :rotate:
простенько и со вкусом. Только мр3 лишнее. И вместо PDF я бы предпочёл SVG
надеюсь обещание выполнят, выпустят, а стоить будет баксов 100 :)
antsnark
Post by antsnark »
http://gizmodo.com/#!5752688/i-really-r ... et-is-real - оригинальная новость
http://noteslate.com/ -- сайт проекта
блокнот выигрывает только 2мя вещами:
-независимостью от электричества
- :rotate: компактностью
Different
Post by Different »
280 грамм многовато, ИМХО. И еще солнечной батарейки на задней панели не хватает.
А приятная штуковина на вид и по описанию...
antsnark
Post by antsnark »
Different wrote:280 грамм многовато, ИМХО. И еще солнечной батарейки на задней панели не хватает.
её обещают опенсорснуть :kruto:
т.е. очень вероятно заменить PDF на SVG
ну а солнечной батареей дополнить можно и самостоятельно :)
но аккуратно сделать не выйдет. Ну и вес вырастет
Кстати, помнится, толи в ЮТ толи в МК тори в ИР встречал схему девайса... Девайса не простого, а который энергию собирает из вещательного радиодиапазона. :kruto: Там, помнится, было 3 магнитных антенны, и вроде выпрямители. И писали что девайс работает тразу после сборки. Дескать, мощность у него невелика, но для питания чего-то простенького хватает.
Такая штука даже лучше СБ. Лежит планшетка в рюкзаке и заряжается :lol:
В марте буду дома - поищу.
Different
Post by Different »
antsnark wrote: Кстати, помнится, толи в ЮТ толи в МК тори в ИР встречал схему девайса... Девайса не простого, а который энергию собирает из вещательного радиодиапазона. :kruto:
Это не надёжно, так как мощность будет сильно падать при удалении от передающего центра. Нужна именно солнечная батарея, чтобы можно было вдалеке от цивилизации...
Сейчас уже есть плёночные СБ, которые весят сущие граммы по сравнению с СБ на стеклянной подложке. Да еще и за счет уменьшения аккумулятора можно выиграть вес.
Как - то бывал я недалеко от передающей радиостанции.
Там местные жители фокус показывали: от петли провода через
силовой диод зажигали небольшую лампочку.
Но за это, говорят, жУчат...
На мой взгляд, в крупном городе от 3-х антенн на крупные станции
маложрущий девайс запитать можно.
Это не значит, что я против солнечных батарей. :wink:
Different
Post by Different »
Можно добавить еще сбор энергии вибраций. Например, использовать тряску при езде в транспорте, ходьбе и т.д. Динамомашину не рассматриваем... :)
Кстати, а почему так мало уделяется внимания системе питания для недопц? А то начинает складываться стереотип: nedopc = слабое устройство, нехило кушающее электричество. Даешь НЕДОБП для НЕДОПЦ!
Different wrote:сбор энергии вибраций
Видел такой узел в электронных часах - баланс и катушки кажецца.
Ну ты не совсем прав. Прежде чем делать "Специалиста" я спаял БП
на 5А с защитой. Я тогда на работе как раз БП конструировал. :wink:
Different
Post by Different »
Lavr wrote:Прежде чем делать "Специалиста" я спаял БП
на 5А с защитой.
5А - это ж серьезный БП. А НЕДОБП - это когда запитываешься от разницы потенциалов между занулением и батареей центрального отопления :)
Или с генератора на пьезопищалке...
Different wrote:НЕДОБП - это когда запитываешься от разницы потенциалов между занулением и батареей центрального отопления
Наверное ты прав... мой второй период "визга" от микропроцессоров
как раз начался когда я обнаружил, что есть чипы питающиеся от 2-х
иголок, воткнутых в лимон. Особенно меня потряс чип, приделанный
к голове таракана и берущий энергию от управляющего ВЧ сигнала.
Сейчас уж не найду эту картинку - жалею, что не скопипастил. :cry:
Но вот неплохой пример.
http://www.ng.ru/science/2005-03-23/15_kiborg.html
А так у меня уже энтуазизм начинал спадать: процессоры типа могут
всё, но "жрут" - как паравозы уголь. :lol:
Ну а 5А БП - это по юношеской наивности: типа пусть мне крякает
мОзги всё... кроме питания. То есть, я подошел к проблеме питания
тогда очень серьёзно. :wink:
PS. А что по этому вопросу думает Shaos?
Может правда сделать ветку НЕДОБП для НЕДОПЦ?
Хотя тут есть сомнения - вряд ли кто любит
с ними отдельно возиться. Прямого эффекта нет.
Если уж сбацал недоКОМП, то он ЗАРАБОТАЛ!!!
А вот БП...
:oops:
ну по мне самый простой БП - это блок батареек ;)
Интересно - а чем вот такие "гаджеты" запитывают?
http://libymax.ru/?p=9722
