полупроводниковый синапс из MIT
antsnark
Post by antsnark »
http://feeds.boingboing.net/~r/boingboi ... napse.html -- ссылка с новостью
собственно чип-синапс
MIT researchers have fabricated a computer chip that uses 400 transistors to mimic the activity of a single brain synapse, the junction between neurons. The device is a step toward in silico simulation of plasticity, the ability of neurons to adapt based on new input.
While most chips operate in a binary, on/off mode, current flows through the transistors on the new brain chip in analog, not digital, fashion. A gradient of electrical potential drives current to flow through the transistors just as ions flow through ion channels in a cell.
“We can tweak the parameters of the circuit to match specific ion channels,” Poon says. “We now have a way to capture each and every ionic process that’s going on in a neuron.”
The MIT researchers plan to use their chip to build systems to model specific neural functions, such as the visual processing system. Such systems could be much faster than digital computers. Even on high-capacity computer systems, it takes hours or days to simulate a simple brain circuit. With the analog chip system, the simulation is even faster than the biological system itself.
Another potential application is building chips that can interface with biological systems. This could be useful in enabling communication between neural prosthetic devices such as artificial retinas and the brain. Further down the road, these chips could also become building blocks for artificial intelligence devices, Poon says.
ну и совсем исходная новость:
http://web.mit.edu/newsoffice/2011/brain-chip-1115.html
Та же новость по русски:
http://hitech.newsru.com/article/16nov2011/mitneurochip
